KeyShot 6 anti alias
I can't find the place to change the anti alias settings in KS 6.
Somebody who can help?
This is an elips:
https://i.imgur.com/mYT0jaR.png
That setting was here:
https://i.imgur.com/F7McWP4.png
Solid Edge 2019 & AutoCAD 2019 user
10 REPLIES 10
Re: KeyShot 6 anti alias
Bedoel je dat die in stappen de pixels scherper maakt?
Dat is nu inderdaad compleet anders, niet dat ik het erg vind.
Moet wel zeggen dat Keyshot 6 erg traag is vergeleken met Keyshot 5.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
De afbeelding is een gerenderde afbeelding...
Ik wil dat die elips er niet zo hoekig uitziet.
Ik ben erachter gekomen dat als je in Solid Edge de Sharpen (View - Style - Sharpen) hoger zet dit in Keyshot ook beter wordt. Daarna een update geven naar Keyshot.
Dit werkte ook zo met Keyshot 5
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Found the solution:
https://i.imgur.com/aISa11T.png
Man Embarassed
OK, this is not good...
https://i.imgur.com/xlwjgI8.png
anti aliasing on 8!
So Now I need to reopen SE, open the model, edit the appearance in SE, update to keyshot, render.
Am I the only one who thinks this is going from Brussels to Paris trough Berlin???
AND IT GETS WORSE!
After updating the keyshot render the materials are all changed to brass!!! So now I need to reasign my materials.
What was the phrase again?
ST works 100 times faster?
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Did you try modifying KeyShot Options -> Output quality?
BR,
Imics
A solution, nice tip
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
I am getting realy p*ssed. Don't understand what's happening:
https://i.imgur.com/2auLb2E.png
The part isn't visible in KS.
After looking in SE (do nothing!) I choose for update KS model the part comes visible, but 80% of the parts change from the choosen material into brass!
https://i.imgur.com/NKj9RfB.png
