KeyShot view settings?
has anybody a hint for me, which option or parameter is defining the quality of the KeyShot view resoultion, or to be precise: "the view resoultion vor circle display"
As You can see, I have set my Solid Edge options to either "High Quality" (value 4 or 5) or to automatic sharpeness of arcs again with values 8,9,10 and high.
The screen quality within Solid Edge is pretty good, but changing to Keyshot will bring a very poor circle display not taking care about my SE settings.
Thanks for any tipps and hints
Wolfgang
Wolfgang
Re: KeyShot view settings?
problem solved!
I just saved the SE file again, closed SE and started it new.
And voila KeyShot has taken care about the changes!
But believe me, I saved the file before too, changed the sharpness settings, started Keyshot new, but ...
Thanks and regards
Wolfgang
Wolfgang
