Keyshot installation
I am trying Keyshot and had installed it automatically through SE. When I had Keyshot open, I checked for updates, found one, ran the update and then Keyshot crashed. I could not get it run so I uninstalled Keyshot but now cannot get SE to re-install it again. Anyone know a work around for this?
Peter
Re: Keyshot installation
If you browse the installer DVD to Solid_Edge_DVD_ENGLISH_STx\Solid Edge\ISSetupPrerequisites\ theres a few folders with long hex filenames, one of those has keyshot_w64.exe inside which you can use to manually install keyshot.
Note; if you only have the downloaded .exe installer, you can extract this with something like WinRAR to find the above file.
Perfect. Thanks.
Peter
