Keyshot two side label
01.JPGPerfect02.JPGProblem
Hello there,
Anyone know how to remove the two side label option?
Maybe I'm doing it wrong?
thx
Good Marketing makes the company look smart.
Great Marketing makes the customer feel smart.
Re: Keyshot two side label
If you double click the material that has the label applied to it, select the Labels tab and then scroll down, you can turn off the Two Sided option.
