LOST DRAWING VIEW COMMAND
For the first time w/ ST7, I went to create a drawing view from the model. I keep that command on my Radial Menu in the Draft environment. However, it's greyed out and won't work. I bet somewhere in the Options dialog, I need to check or uncheck something but I can't find it. Thanks, Ron
Re: LOST DRAWING VIEW COMMAND
I solved this problem myself.  Apparently, I had a command icon in my Radial Menu that looks almost identical to the command I wanted.  I wanted the command named: 2D Model = Creates a view of 2D Model Geometry.  What I had was a command called Drawing View.  The icon for each is identical except the tiny square box in the upper left corner of the icon is a slightly different color combination.  The one I wrote about has the box filled in with a blue gradient but the desired command has a red outlined box which is not filled.
