Language
Not applicable
Can I change the language in ST6? Or is english the once language?
Kind regards
Re: Language
You must downloaded the correct language.
Sent from my Motorola Electrify using Tapatalk 2
http://Grundey.blogspot.com
Re: Language
Not applicable
When i will select the german type then restart the page and it doesnt stop... that was by my first download the same... Because this problem i had downloaded the english type. by the way.. sorry for my bad english. Do you can tell me what the problem is?
This is the link https://www.plm.automation.siemens.com/trialcenter/download
Re: Language
Not applicable
Noboy cant help me ?
