Latest Revision of Part file is not calling (From Team Center 10) while open an assembly in ST9
4 REPLIES 4
Re: Latest Revision of Part file is not calling (From Team Center 10) while open an assembly in ST9
@DNSKMR You may need to provide some more information as to what you are attempting to do, like what Revision Rule you are using and what the status of the part revision is that you are asaying won't download.
http://Grundey.blogspot.com
@DNSKMR  as @KennyG  says,  my guess is that this is a rev rule issue but need more info.
It has been my experience that Latest Working/Released (OOTB) uses creation date and if you have a situation in TC where REV01 has a creation date prior to REV00 then you will get REV00 as the Lastest Working file...
Matt Johnson
Solid Edge Certified Professional
Solid Edge 2019 (SEEC) - Production
NX12 (Tc Integration)
Teamcenter 10.1.7
Thank you
Thank you
