Licence can be used again
N/A
Hi
Unfortunately I had to reinstall my OS and Solid Edge went with it. Although I can download the software from the email sent previously, the licence won't work so if it is possible could you issue me a new one on either dg00096@surrey.ac.uk or better is gyimesidavid@gmail.com.
Thank you very much in advance,
Re: Licence can be used again
Hi David,
What message does Solid Edge ping back to you about the license you have?....it could just be the License Utility & your OS battling it out, in which case there is a manual method to place it.
Solid Edge ST10 [MP7] Classic [x2 seats]
