License Borrowing dialog box is blank
Hi Edgers, I hope you all doing great. I m in need of a little help here.
As I have came up with a problem in License Borrowing feature.
I carried out following steps.
- Copied the license file from server PC and replaced it in the client PC directory
- Toggled down the "User Account Control" settings to "Never Notify"
- After above steps, restarted the client PC and opened the "License Borrowing" application in "Run as Administrator" mode.
Even after carrying out these above steps, I m encountered with the same problem.
(Please find the attached Screenshot)
Thank you in advance.
Have a great day!!
Re: License Borrowing window is blank
What kind of operating system do you use? Win10?
BR,
Imics
Yes. It's Win 10
Warm Regards,
Amit Garag
