License Utility Install
I installed SE, followed the steps to License Ultility the next step shows SE in use, close session and restart. What is the reason for this.
I recieved a student download Aug 30th. I downloaded numerous times finilly got it installed.
Thank You
Re: License Utility Install
Hi Greg,...so is Solid Edge [Student Edition] now able to be run on your system, or is there another issue?
Hi Sean,
The issue is the License Utility Install. I received an upgrade from
Mike Brown
Director, Solid Edge Academic Relations
www.facebook.com/solidedge
After the issues with installing SE for the umpteenth time... Getting
finally closer to get back for school,work.
I never received a License from SE. For about a week trying to get in touch
with Siemens to get this issue resolved.
I truly apologize for being a thorn in everyone side.
Thank You
Greg Crouse
1chuzis@gmail.com
