License Utility Install
I'm installing License Utility, set the Acct Setting to low, rebooted, opened up the window to browse to St5, opened ST5 in Local/C: System x86. I come to this (Illustration). I am at a stand still  I checked in the files, I'm missing something. But, What!
http://screencast.com/t/grzd7mgT637T
Greg
3 REPLIES 3
AHA...you need to browse to the license file from Siemens...
AHA...you need to browse to the license file from Siemens sent to you via your email. [save that file teporarily to your desktop...can delete from there, after install]
The License Utility will take care of the rest.
Re: AHA...you need to browse to the license file from Siemens...
That's the problem I never received an email from Siemens for the License Utility Install.
Thank You!
It will be in the same email sent to you with the link to download the program.
If you still do not have this, then just go through the sign up process again, to get the email. [with License & D/L link]
