License Utility not opening
Hey, I used Solidedge st5 for about 1,5-2 years ago (and now the license file have expanded) and now I need it for a new project and im trying to open up the License Utility progrem but it just gives me "The solid edge license file is currenlty in use. Please exit your solid edge session then restart the license wizard." no matter how much i restart my computer this keeps popping up. I don't have a new SELicense.dat file so i can't change them out manually but i have an acedemic code. So I need your help to teach me what i can do to renew my acedemic code.
Re: License Utility not opening
Run As Administrator.  Right click on the entry in the start menu and select "Run As Administrator".
Production: ST10 MP6
Testing: SE 2019
