License error when add a new family of parts
When I try to add a new family of parts in Standard Parts administrator from Family Part Master it appears the following message "license number of users already reached". However, if I try to add a simple part I can do it withouth any problem. Do you know why this error appears?
Please, see attached image.
Thank you in advance.
Betreff: License error when add a new family of parts
Hi @EvaF
which license of Solid Edge are You using?
Classic or Foundation?
Wolfgang
Hi @hawcad
It is a Classic license.
Hi @EvaF
so I suppose that for changing or add parts into library a free SE Classic is necessary and according to the message they seem to be in use.
So if there are logged off some SE users, what will happen then?
Wolfgang
Hi @hawcad
I think so, but if I add a part from "add to manual data entry" instead "add From Family Part Master" I can add it without any license.
You can see this in the screenshots.
Thank you
Hi @EvaF
I also only can suppose that in that case a Foundation license is enough - since YOu can use Standard Parts Library functionallity with Your own parts with Foundation also.
But in detail this must be answered by a developement person who knows it exactly.
Wolfgang
Hi @hawcad
Thank you.
