License file missing
N/A
I just registered for the Solid Edge Eductaion version and could also download it by using the link in the mail, but I did not get a license file in the attachement.
What can I do?
Best regards
Andreas
Re: License file missing
N/A
Hello Andreas,
Mine had a SELicence...txt file attached to the download email. Save it to a folder you create, say for Solid Edge. Towards the end of the install the wizard will go to a window where you can put your name, etc. There will be a couple blank fill-in boxes towards the bottom of that window. For the one that mentions a license, browse to the folder where the .txt file now is and select it. The other box you can leave empty. That should do it.
