License file not received till now
I downloaded solid edge academic v10 from official website but i just got the confirmation email. After confirming my email i have not received any emails from plm regarding licensing or academic code. Plz help me i have project work to do
7 REPLIES 7
Re: License file not received till now
The license file should be in the Solid Edge install file that you downloaded.  Did you run the Solid Edge install yet?
Yes
And did you then actually start Solid Edge?
I have no license file or folder in solid edge st10 folder. I gave all my information then clicked on download. Got downloaded an exe file. Extracted it then installed solid edge. Now the license utility is open but i dont any license file or academic code. No emails received regarding licensing
You do not extract the downloaded exe file -- you double-click on it to start the install of Solid Edge.  If you extracted the files manually then the Solid Edge will not install properly and you will not have your license file.
If you install by double-clicking on the downloaded exe file then your Solid Edge license file will be automatically installed for you.
As you are capable of and have already manually extracted the files from the downloaded exe file then you should be able to locate the selicense.dat file that is part of that downloaded exe file and manually copy it in to the correct location.
If you are not able to do this then uninstall Solid Edge and reinstall it correctly by double-clicking on the downloaded exe file.
I right clicked and selected run as administrator then the exe file automatically started extracting and i have checked every folder license.dat file nowhere to be seen
Sorry for the delay -- went to lunch.
Please IM me your e-mail address.
Thank you and regards,
-Dave
