License...required?
Downloaded and installed solid edge 2d ST9 and can not find the informatioin to license the appliction?
7 REPLIES 7
Re: License...required?
Where you sent an e-mail when you registered with an activation code or something?
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
I assume you tried to run the software and you at that time get a license error. Is that the case?
I ask because the license is built in. Installaion of the software should apply the license. You do not need any license code.
Rick B.
Sent an email but no activation code
Sent via portable
akbarron@gmail.com
tried to run and it came back with request for license information?
got an email following my registration, which got me to the download page.  No password or webkey information.  Activated account and still no insight on webkey or license; all I have id SE CID number (on the screen asking for license)
Capture.PNGscreen at start-up
I want to make sure we are talking about the same thing. The image shown is the License Utility. It is not the Solid Edge application. If this is what is shown when you run Solid Edge then there is something about your system that did not allow the license to be applied properly. I can send a license to you with directions on how to apply the license manually.
Rick B.
