Limit number of characters via propseed.txt
Many of you are familiar with using propseed.txt to standardize entries in file property fields, but does anyone know if it's possible to format an entry to limit the number of characters the user can enter?
Russ
Re: Limit number of characters via propseed.txt
other than limiting the type of input (text, date, boolean) ,  Im not aware that it is possible to limit a text type to a certianl # of charicters..
