Line Type on Part
Can we select a line type linked to the part property so if the part is show in a detail or view in a draft, the line type will always correctly applied?
I have to make different views of an assembly with some parts that I want to have different line type applied on and I don't want to search for the parts in all the views to change de line type.
Thx for your help
Alex
Good Marketing makes the company look smart.
Great Marketing makes the customer feel smart.
1 REPLY 1
Re: Line Type on Part
I'm not sure if this would work for you, but you could mark some parts/assemblies as reference, then they will show up as whatever you have reference lines set up to be. But this would only allow you to have two types, reference and non reference.
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
