Link excel to property draft
hi all,
Is it possible to link to excel and the property draft.
I know to do link between variable and excel but on the table of variable it's not possible to use a format text.
Thanks for advance for yours answers
7 REPLIES 7
Re: Link excel to property draft
dont know of any way to link excel to prop text directly but as you say, you can link to a variable and you can expose a variable to be used as property text.  so i think tha tis your workflow...
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Hi Matt,
Thanks for you answer.
I don't know how to initialize a variable in text format. Only a numeric variable...
yea,  agree with you there...  hmmm....
Matt Johnson
Teamcenter 10.1.7
Honored Contributor
Honored Contributor
Excel can be used to drive variables. That works well and is stables
Getting information from SE to Excel, no way to create links and updates. One time transfers can be done.
As a result, using tables from excel as a work around for no variables into SE tables is not an option.
Is it possible to use VBA excel to modify custom properties.
@cedi,  Yes,   VBA or any programming interface you prefer can be used to modify properties...
SE has an exposed API...  you will find many examples and more detailed info inteh SE Developer forums:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/bd-p/SEDeveloperForum
Matt Johnson
Teamcenter 10.1.7
Thanks Matt!
I look on this forum.
