Link formatting
Honored Contributor
Honored Contributor
Hello all,
I'm linking dimensions to a spreadsheet for some math to be aplied to the linked dimension. Only I can't perform any math on a link that contains units. How do I remove the units from a linked dimension?
Re: Link formatting
Honored Contributor
Honored Contributor
I found the answer: Under options, general, uncheck "Show units in value fields"
Re: Link formatting
Great find 12GAGE, except the variable table needs to be restarted - but very useful.
