Lip
I was wondering how Solid Edge translate "Lip" in the french software :
Tanks
Re: Lip
This can be typically found under "Thin Wall"
Follow the icons in this image:
Alternatively, you can use the Command Finder at the bottom of the Solid Edge window.
Re: Lip
Great ! Can you tell me how the word Lip is translated in french ?
Re: Lip
A quick look in google gives Levre.
Edit: maybe "le bord" is more appropriate here.
Bruce Shand
Re: Lip
Thanks. Actually i was looking for someone using the software in french to have the exact terminology
Re: Lip
excusez-moi. Smiley Indifferent
Bruce Shand
Re: Lip
Voilà Smiley Happy
If you use IE, you have to change the display language from French to English und you could use the same link from the Solid Edge help website
https://docs.plm.automation.siemens.com/tdoc/se/107/help/#uidSmiley Tonguelstc2c
Yasser
Re: Lip
Thanks for your help Man Happy
Re: Lip
PERFECT Man Happy
Big thank you
Re: Lip
@veronique, you should mark Tushar's and YD's answers as solutions.
Bruce Shand
