List of Cad Libraries which are compatible with c#.net??
PLM World Member Experimenter PLM World Member Experimenter
Hi...
    I want to know which cad libraries are used to genrate drawing throgh c#.net.I want to take input from xml file & generate 3D & 2D drawing.I Want to know list of cad libraries??
   Thanks..
Re: List of Cad Libraries which are compatible with c#.net??
If you are enquiring about Solid Edge APIs then there are no special libraries for programming Solid Edge. You just add references to the pertinent type libraries. For example, draft.tlb.
