List of SolidEdge keyboard shortcut that could be used inside SE commands?
Does anybody knows some list of Solid Edge keyboard shortcut, that could be used inside SolidEdge command?
The following Help page explains how to get a list.  Keep...
The following Help page explains how to get a list.  Keep in mind that these will be different for each environment so you will have to switch between the main ones to see all of them.
http://support.industrysoftware.automation.siemens.com/training/se/106/en_US/index.html#uid:keybd4d
http://Grundey.blogspot.com
Re: The following Help page explains how to get a list.  Keep...
Hello Mr. Grundey.
Thanks for your feedback, but I mean inside the commands, not to reach the commands.
For example, there are some shortcuts that can be used like:
- Alt for preview, when I want to place a dimension in the Synchronous;
- Alt to attach a disconnected dimension
- "L" and "C" inside the command of Line, to alternate between Line and Circle.
Does anybody have a list of those tips?
Usually we learn that during DEMOS but could found up to now any detailed document.
Thank you very much.
Eric
