Local Help Server is down again after several weeks of working
Esteemed Contributor
Hi Edgers,
just faced again the situation that my local help server was not started due to a services problem with Siemens Documentation Services.
This happend a time and now again.
I had no chance to run those services again, only after uninstall and reinstall those service with a previous reinstallation of jre1.84
My suppose onl could be, that some system update of windows changed the java version to a newer and more current one but this will not work together with the Siemens Doc Server
Why do I think this?
When not changing JRE back to 1.84 an error message appears during doc server installation, showing that it could not be installed due to a jaa parsing problem
Install jre1.84 and everything is running again,
... until the next windows update  Man Sad
Wolfgang
