Local section.
HI everyone.Question for experts.
I know to do any cut sections  in SE.
3 REPLIES 3
Betreff: Local section.
HI @VitaliyV
this also is not a real problem.
See or look for "Broken-Out" view
(view in My Videos)
Wolfgang
Thank you very much. You are a genius !!!!!!
Hi @VitaliyV
thanks for Your nice words, but no, I'm not a genious only older and more time with Solid Edge, that's all.
If Your problem is solved, so You can mark it as solved, to make it easier for other following the issue and findeing solutions.
Wolfgang
