Looking for more info related to PR 8957904: Line missing in dxf when using save as flatten
Seeing as we have had lot more dxf issues at our laser, I wast curious what this involved,  For example, what MP did it start with?  What was the specific steps to see the problem.
Thanks in advance for your answers.
Re: Looking for more info related to PR 8957904: Line missing in dxf when using save as flatten
@MikeSaari looking at the notes for PR# 8957904, this issue was first reported in ST9 MP9 and ST10.  This issue should now be fixed in ST9 MP10.  ST10 MP1 has not been released yet.
Simply saving as flat to DXF resulted in some arcs being missing from the geometry resulting in an open contour of the flat part profile.
We are seeing DXF errors at our laser which says:DXF issue no segment found.  I wonder if it could be the same thing.  What seemed to help us out is to quit using v14 for the DXF's and go back to v12.
