Lost images
Not applicable
Sometimes when I FIT VIEW, I lose the working elements. I appears as if I'm taken to such a far mangification that I can't see my work. This is true even if I SELECT ALL. I believe that I could have an element so far from the main work thur some error on my part that's doing this. How do I rectify this?
Ron
Re: Lost images
Not applicable
Are you opening AutoCAD drawings when you see this problem?
Rick B.
Re: Lost images
Not applicable
No, just SE V102. And it's only happened once. After posting, I opened a new file and copied over want I wanted.
It probably was some fluke I did with a dimension without realizing it. Forget it.
Ron
