Low Memory Always Comes Up
Just got this computer back this morning installed the ST6 2014. As soon as I loaded with an image the low memory came up again. How can I get Solid Edge up and running.
This is the description
http://support.boxxtech.com/support/product_detail_or.asp?MBID=30264&Serial=B145051
Thank You
Greg
Re: Low Memory Always Comes Up
Esteemed Contributor
This was an issue with the initial release of ST6 and was cured in a Maintenance Patch which is not normally available for the Student Version.  There may be an exception for this one, but I'm not aware of it.  You may want to try contacting GTAC or a local VAR.
Production: ST10 MP5
Testing: SE 2019
Wow, that a great system...seems very strange that you'r getting this message on low memory.
Sorta seems to me, that you really need to be moving to a commecial version, to match where your designs, from what I have seen, are headed.
Solid Edge ST10 [MP6] Classic [x2 seats]
