MAJOR MENU PROBLEMS - LOST AND CAN'T FIND, AGAIN!
N/A
Ricky, no sooner than closing this issue and it happens again. I was ONLY making changes to the Keyboard custom settings. After saving to my custom name, I OK’d and found the Model QA menu had reverted to the default. I checked my QA menu for Blocks and found it also had reverted to the default but not my Draft QA. If this is something I did, than customizing needs to be made less tricky. But since no similar complaints have been registered, than there is something unique about my work process and/or my software.
I will redo my settings again.
Ron
