MORE THINGS I DON'T LIKE
Not applicable
The precision move function turns off after each move. With V19 & 20 if the Precion
Move was turned on before the highligh action it would stay on until another function
was chosen.
If a highlight was done with the Select function and then the Precision Move was
selected, it would turn off after the move but the element(s) remained selected
which allowed a click of the Precision Move button to make an adjustment.
IMO this was a very effective way for the function to work.
Larry
Iceman
Re: MORE THINGS I DON'T LIKE
Not applicable
Larry,
What is this precision move you are talking about? I searched the help file for
"precision move" and came up empty.
Ed
>Precion
>function
>was chosen.
>was
>Larry
>Iceman
Not applicable
"Ed Kadlec" wrote:
>Larry,
>for
>Thanks,
>Ed
>the
>>Precion
>>function
>>was chosen.
>>was
>>Larry
>>Iceman
Larry
Not applicable
Ed, Sorry about not resonding sooner. I've been laid off from the company I worked
for.
In the Sketch/Draw box there is a yellow cross with arrows icon for the MOVE function.
When you place the cursor over it the help pop-up reads "Moves elements with precision".
On V20 if the Move function was activated, several moves could be made in succession.
Now when a move is done the feature is resent and if another move is desired the
Move feature must be clicked first.
Larry
"Ed Kadlec" wrote:
>Larry,
>for
>Thanks,
>Ed
>the
>>Precion
>>function
>>was chosen.
>>was
>>Larry
>>Iceman
Larry
