MS material
I want to know that is there MS(Mild Steel) available in Material library or not?
Re: MS material
Hi there @Raumik,
If you double click the "Material" listing in the "Feature Pathfinder".....this will open the material table dialogue box....then assign it as desired & click "Appy to Model".
Solid Edge ST10 [MP8] Classic [x2 seats]
