MULTI COLOR SKETCH DISPLAY
I accidentally selected multicolored sketch display for a sketch in my flat pattern, and now I can't get it to go back. The options for that sketch are now greyed out so I can't select single colored or uncheck multi color. This is very annoying because when I'm in another sketch and selecting elements from that sketch, I cannot tell the difference between the sketch i'm currently in or the sketch I activated this in. Then in a moment of brilliance I decided to activate this intentionally in another sketch, same result, cannot turn it off. Any ideas?
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
12 REPLIES 12
Betreff: MULTI COLOR SKETCH DISPLAY
Hi @nominus38
Right Mouse Button and "Single Colore Sketch Display"
Does here exactly what it should!
@hawcad,
As I said, that option is greyed out and unavailable for this sketch. Don't know why, don't know how, but it will not let me select that.
(view in My Videos)
Solid Edge 2019
Hi @nominus38
can You upload the file or show at least a screen shot from the complete Solid Edge window?
Hi @nominus38
sorry, just now was able to see Your video.
Wasn't visible till yet.
Hi @nominus38
for Your information:
is just the same here with a sketch in flat pattern mode.
Once changed to colored, no way back to single color!
Seems to be a bug!
Sorry I ruined your flat pattern.
Solid Edge 2019
this appears to be an IPA...  I believe you can only toggle the sketch color with the part is open...
try to Open the part and see if you can then toggle the setting.
Matt Johnson
NX12 (Tc Integration)
Teamcenter 10.1.7
Hi @Johnson_BigMatt
no, not IPA.
Just had a single PSM with flat pattern.
Exactly the same situation!
Tried. Does not work.
Solid Edge 2019
