MYSTERY COMMAND/SHORTCUT KEY GRID ORIGIN
Not applicable
I was wanting to make a shortcut key for REPOSITIONING GRID ORIGIN but couldn't find
the command in the MORE COMMANDS/KEYBOARD/. Is there a way to do this?
In looking for this key, I came across a MORE COMMANDS/KEYBOARD/TOOLS/AUTOMATICALLY
REPOSITIONS TARGET which is defined as "Automatically repositions the snap to grid
target beneath the cursor". I couldn't find anything in HELP about this command
so I assigned a temporary shortcut key to see what it does and nothing happened
when I invoked the command.
Please answer my first question and you can check the second one to see if there
is a disconnect somewhere.
Ron
Ronald W Latour
Re: MYSTERY COMMAND/SHORTCUT KEY GRID ORIGIN
Not applicable
Ron,
It's under the "Grid" option. I added the "Grid" tool to the quick access bar and
when you click on it the options appear on the lower left of the screen below the
prompt bar. One of the options is for repositioning the grid origin. Hope this helps.
Ed
>find
>to grid
>there
>Thanks,
>Ron
>Ronald W Latour
Not applicable
Ooops! Sorry Ron. I didn't read your message accurately. You are looking to assign
a keyboard shortcut.
Ed
"Ed Kadlec" wrote:
>Ron,
>bar and
>the
>this helps.
>Ed
>>find
>>to grid
>command
>>there
>>Thanks,
>>Ron
>>Ronald W Latour
