Macro for updating drawing views on the active sheet only
Edgers,
The Solid Edge 'Update Views' command updates all drawing views on all sheets.
Attached is a macro for updating all drawing views only on the current i.e. active sheet.
Tushar Suradkar
www.SurfAndCode.in
www.CADVertex.com
Re: Macro for updating drawing views on the active sheet only
Great Macro, very useful!Robot Happy, would it be possible to have a version that updates all the entries including hole tables and parts lists etc. on the sheet or would that be too complicated to set up?
Thanks for the appreciation, I am glad you found the little macro useful.
Solid Edge does not allow accessing Parts Lists and Hole Tables on a per sheet basis as in the case of Drawing Views, hence it is technically not possible to add this feature. Robot surprised  Robot Sad
~Tushar
I appreciate asking for enhancements upfront, unlike PMs that flood my inbox and which I hate.
www.SurfAndCode.in
