Macro request-draft env (hidden lines)
Esteemed Contributor
I've always wondered why there isn't a quick link to this function in the view ribbon.
Instead, one has to select a view, open properties, click "hidden edge style" radio button, apply or ok.
I don't care much that "show edges hidden by other parts" follows the above selection by default. I would just like a toggle: if they're on turn them off and vice versa.
Bruce Shand
Betreff: Macro request-draft env (hidden lines)
Honored Contributor
Honored Contributor
I have written a macor, a couple of years ago, which made this job easier.
It allows to change the view styles in one or more views with a single click.
The onyl issue at the moment is, that now it is German only.
But give me a short time, and I will provide an English version too!
Wolfgang
Wolfgang
Danka shein. Nice, I figured out the German and it's nice that you can pick multiple views and it has the 3 main options.
However, now I'm going to whine a little.
- It doesn't maintain the last selections and defaults to off.
- I still think a simple toggle for the first two settings would be nice since for me they are the most used and it reduces clicks considerably.
Bruce Shand
Honored Contributor
Honored Contributor
Hi Edgers,
as attachment You will find an English Version of my ShowHide macro for SE drafts.
How does it work?
Start the macro, select all the views within a draft You'll like to change the view styles.
Then chose the settings for hidden edges, hidden by part edges (for ASM drafts) and tangent edges.
Push the Apply button and done!
Hope it helps
Wolfgang
Wolfgang
Being a bit pedantic here, but could we have an option not to update the views automatically ?
HP Z420 16GB RAM
Quadro K4000
ST10 MP3 on Windows 10 Pro 64.
Honored Contributor
Honored Contributor
as always, barely given a macro for free, the wishes come up.
But it is a pleasure to help, and I hope this is what You were looking for.
Wolfgang
Wolfgang
Re: Macro request-draft env (hidden lines)
bshand
is this option off all the time?
@TDB
If you mean the hidden lines, etc., no. It depends on your default settings and/or your manual settings when inserting a view.
Bruce Shand
@beachcomber,
"an option not to update the views automatically"
Not following that. I've never had views update automatically. They get the continuous thin lines around them indicating they need to be updated but you have to command it.
Bruce Shand
@hawcad,
Again, thanks.
Bruce
Bruce Shand
