Make a Pattern In An Ordered Doc.
In this image I am attempting to build this pattern highlighted in blue. I looked in help I've tried sketch component, tear off, tried all of the curve command, since the part is loaded with curves. I've tried free hand
.http://screencast.com/t/jsxMNCCKJf
Thank You
Greg
Re: Make a Pattern In An Ordered Doc.
Esteemed Contributor
Greg, I see a face (or part) highlighted in blue, but no sketch geometry of the "pattern" you want to create......what are you trying to do here? Pattern features?, or pattern a part??, in what modelling environment???
Sean,
I tried to create a geometry sketch could not. A pattern feature. Similar
to using a pencil to create a etch on a sheet of paper. The modelling
environment in sketch is ordered. Tried the sync part nothing would happen.
Thank You
Greg
Are you trying to "include" the edges? We now call that "project sketch" in sync but still include in ordered.
see this video to see if this is what you want?: http://screencast.com/t/1xSpDm5ANTw
HTH?
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
