Material copy
Hello to all. I tried to find out if there was a discussion that could do for me, but finding nothing I try to ask you what I would like to do.
When I create a new material, can I copy all the values I have highlighted and copy them as new material data?
In some cases the new material needs totally different values, but in others
Instead, cases remain all the same and I would like to not rewrite all the data manually. It's possible?
Thank you all.
Re: Material copy
Yes. When you click New in Styles, you get the New Face Style window pop up. Click on the Name tab, where you enter the name for your new material and underneath this entry is Based on. Select a material in this field which is closest to your new material and the parameters will be copied across.
Edit: Sorry, I had brain fade and got confused between Face Styles and Materials Smiley Embarassed
585 ST10 Win 7
Betreff: Material copy
Hi @And_M_One
no matter at all!
You can copy whatever You want to copy.
The complete material, some material properties or onoly one.
Not only one material, but also a complete material group.
See video:
(view in My Videos)
Wolfgang
You're the best and your video is so easy! Thank you so much my friend!
Hi @And_M_One
welcome and thanks for Your acknowledgement, this always can drive You to continue!
Wolfgang
