Material scalling issues within Keyshot
Can anyone point me to write ups on how to set up or how correct scalling issues with materials? If you look at the image you will see the circled areas where the scale on the wood and the stainless steel is to large but the scale on the conceret floor is to small. I keep running into this issue. there must be an easier way to change it.
Nathan M. Gardner
https://www.etsy.com/people/NathanMGardner
Be sure to check out my work!!
Made in Maine Wood Carvings
Re: Material scalling issues within Keyshot
If you select the Material and using 'edit material/texture/scale' you can adjust this.
Regards /ulf
Siemens EMEA GTAC Support
