Measurements and Scale drawings
Not applicable
I'm a newbie to SE, but after several hours of mucking about, running the tutorials
and searching on this message board, it seems that I have to draw things in a 1:1
scale. Is this true?
I tried the trick of drawing in the 2d Model mode and then placing onto a sheet,
but I have no idea what that's doing. On a 2d Model page a bunch of features don't
work, such as driving dimensions, etc. On that page a rectangle is just four unrelated
lines. I don't understand.
Is there no way to simply create scale drawings with measurements that are accurate?
3 REPLIES 3
Re: Measurements and Scale drawings
Not applicable
Ken,
In order to be able to use driving dimensions and relationships you have to
make sure that "Maintain Relationships" is turned on under the Tools Menu
(See attached picture).
This will allow you to use driving dimensions and releations ships to draw
full scale in the 2D Model space.
HTH,
Neil Menne
Sr. CAD Designer
Lochinvar Corporation
300 Maddox Simpson Parkway
Lebanon, TN 37090
Phone: (615)-889-8901 Ext: 2233
Fax: (615)-882-2962
Email: nmenne@lochinvar.com
"Ken Hawes" wrote in message
news:483a4014$1@bbsnotes.ugs.com...
> tutorials
> in a 1:1
> sheet,
> features don't
> four unrelated
> accurate?
Not applicable
Also,
Turning on Tools-Relationship handles will let you see that geometric
constraint symbols
David
"Neil Menne" wrote in message
news:483c15fb$1@bbsnotes.ugs.com...
> Ken,
> to make sure that "Maintain Relationships" is turned on under the Tools
> Menu (See attached picture).
> HTH,
> Neil Menne
> Sr. CAD Designer
> Lebanon, TN 37090
> Fax: (615)-882-2962
>> tutorials
>> in a 1:1
>> sheet,
>> features don't
>> four unrelated
>> are accurate?
Not applicable
"Ken Hawes" wrote:
Thanks very much for the tips--- I'll try that out.
