Merge faces
I am using Solid edge ST7 ,i created a model similiar to the above image ,i need to analyse it using solid edge simulation tool bar how can clean up the faces, because i am facing the Problem during Meshing process.
Re: Merge faces
Dineshkarthi,
It would be best if you could post the part. My first approach is to try and delete the smaller ones one at a time. This usually blends the surround few surfaces.
But to take it further I would want to play with it a bit.
Bob
Re: Merge faces
Could you share this model?
There are same ways to do what you want, but it depends on models.
BR,
Imics
Re: Merge faces
You might want to give the "Redefine" option a try (found in the Surfacing toolbar).  This may allow you to merge those faces together while controlling the edge conditions.  Worth a shot.
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
Re: Merge faces
Try the Inspect tab>Geometry Inspector to identify small faces and delete what you can.
Then modify your study advanced settings Geometry check = Warning Only.
LMGi
www.TLMGi.com
