Metric vs US units selection
Not applicable
Under tools-->options-->attachment Units I have it set for millimeters.
on the dimensioning tool bar I have it set for ANSImm. yet when I create
a dimension and type in the value for it it always defaults to inches
unless I type in the dimension like 350mm. If I type 350 it assumes its
inches and my dimension is 25.4 times too large. How can I set solid
Edge to use only mm?
thanks,
Re: Metric vs US units selection
Not applicable
File-Properties-Units tab. Change units to metric then when you type in 350
it will recognize it as 350mm
David
"Mike Gillespie" wrote in message
news:470e8696$1@bbsnotes.ugs.com...
> Under tools-->options-->attachment Units I have it set for millimeters. on
> the dimensioning tool bar I have it set for ANSImm. yet when I create a
> dimension and type in the value for it it always defaults to inches unless
> I type in the dimension like 350mm. If I type 350 it assumes its inches
> and my dimension is 25.4 times too large. How can I set solid Edge to use
> only mm?
> thanks,
Not applicable
Mike,
You set the units that SE is going to use under File-->File
Properties-->Units. This will also set the units that are displayed on the
ribbon bar.
Hope this helps,
Neil Menne
Sr. CAD Designer
Lochinvar Corporation
300 Maddox Simpson Parkway
Lebanon, TN 37090
Phone: (615)-889-8901 Ext: 2233
Fax: (615)-882-2962
Email: nmenne@lochinvar.com
> only mm?
> thanks,
Not applicable
Perfect! thanks!
Neil Menne wrote:
> Mike,
> ribbon bar.
> Hope this helps,
