Re: Microstation Drawings
@beachcomber I haven't used Microstation - I assume you can't export directly into a DWG/Step instead of V7?
Microstation will export to dxf and dwg, but as I am referring to 2D drawings STEP is not applicable here.
As I said earlier, this would mean 2 translations rather than 1, so an extra process for things to go wrong.
My motto is always to use the minimum number of translations - particularly dimensions and fonts.
HP Z420 16GB RAM
Quadro K4000
ST10 MP12 on Windows 10 Pro 64.
