Migrating SolidWorks API to Solid Edge - New blog article
Edgers,
If you have created macros for SolidWorks in the past and want to migrate those to Solid Edge, start reading this series of articles that give insight into how to use the equivalent APIs:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/Migrating-from-the-SolidWorks-API-Pa...
~Tushar
