Minimal distance for collision detection
Hello everyone
I am relativly new with everything 3D-wise and kind of slided into the 3D-Test-Position at my workplace.
Now I'm looking a bit mor into the collision detection.
Is there a possibility to defina a minimal distance between parts or is it only possible to detect "true" collisions? I have not found a possibility to define such a distance.
Thanks in advance
Betreff: Minimal distance for collision detection
HI @mreisch
this is a request qhere I would use  a Sensor in 3D assembly.
The sensor would be a minimal distance sensor between the observerd parts, with a minimal distance value.
At the moment, when this value is eached or fallen short, a yellow warning sign will appear on screen.
You also can activate a ring tone to warn You about this failure, but this is something I never have done myself
A sign is still good forme.
Wolfgang
HI @mreisch
see a picture from a minimum distance sensor:
Wolfgang
