Mirror in Assembly- Changing All Planes at a time
While using Mirror command in assembly, how to change all mirror planes at a time in 'Adjust' column of 'Mirror Components' window for all  parts/sub-assembly to be mirrored?
Aslam
12 REPLIES 12
Re: Mirror in Assembly- Changing All Planes at a time
Hi @Tushar,
Do you have any suggestions please?
Aslam
Hi @aslam
Sorry buddy, it seems only development can change this.
Normally macros or apps can be created for steps that can be performed manually to save time involved in repetitive steps and avoid errors. This seems to be a built-in behavior that cannot be changed. I tried with multi-selecting and changing at once, including using the Shift and Ctrl keys, but it appears selection and only one list can be manipulated at a time.
There could be a completely different workaround - like grouping all required components to mirror into one body and mirroring them, etc.
Tushar
Betreff: Mirror in Assembly- Changing All Planes at a time
Hi @aslam
just select the complete column and then with RMB go to the wanted action
Wolfgang
Yes, I forgot to mention - when nothing seems to work - then always there is @hawcad !!
Hi @hawcad,
I was talking about 'Adjust' column of the window, not 'Action' column.
The situation is, all components are in rotate mode in 'Action' column and top xy mode in 'ADJUST' column. I want to select the entire 'Adjust' column, then with RMB change all to other plane like yz plane. Is there any way to do that?
I suggest using Find & Replace it works well! Smiley Wink
BR,
Imics
Hi @aslam,
I was confused by Your info about "Mirror" since when mirroring there is no question for adjustment.
For this situation there is only one method I have found and this is via the Find - Replace option of the RMB
Wolfgang
Hi @aslam
and Hi @Imics
I already had written the text and snapped the picture but a phone call prevented me from sending so,
thanks to You lmics, we have found the same method and solution and You haw won the photo finish
Congratulation to gold medal
Wolfgang
Very unusual use of Find & Replace
