Mirror pipe segments in XPress Route
Builder
Builder
Is it possible to mirror a selection of pipe segments in the Xpress route environment ? There is no command as such to perform a mirror of the "sketch" of the segments when in Xpress Route like there would be if in the sketch environment, this would be useful in some instances save sketching out the segments out again in a mirrored plane
4 REPLIES 4
Re: Mirror pipe segments in XPress Route
This function doesn't exist that I know of, but you can use the mirror function in the assembly enviroment to do mirror copies of your XpressRoute parts.
Builder
Builder
Hi Alex
I understand that it can be done in the assembly environment however I would guess by doing it this way the segements are not also mirrored along with the XPress Route part ?
No, the lines aren't mirrored, just the 3D geometry.
Builder
Builder
Many thanks for clarifying this Smiley Happy
