Missing Drafs for Design
PLM World Member Builder PLM World Member Builder
I must of misplaced my drafts for designs.  Am I able to get the dimensions off the drawing to create a draft!. If I can how?
Thank You
Re: Missing Drafs for Design
Not sure what you are asking...  Drafts are the DFT files that you document models (PAR, PSM & ASM) on.  So are you saying you lost your Drafts and want to know if you can get dimensions off the models?
http://Grundey.blogspot.com
Re: Missing Drafts for Design
Yes, that is what I am asking... Am I able to get dimensions off of
the model to make a draft. If this is possible?
Thank You
If you have the model, then create a new Draft and use the Drawing View Wizard to place views of the model in your Draft.  You can then either Retrieve Dimensions or place dimensions as needed.
Crousie,
I'll ask the obvious,...have you done a search in windows explorer for all *.DFT files?
Testing: Solid Edge 2019
