Missing PMI text
Hello Edgers,
I have one question about PMI dimensions in 3D environments.
Some of my customers reported missing PMI dimension text that disappears after some time of work in SE. When SE is restarted, PMIs are OK, but after some time the PMI text disappears again.
On my machine this behavior does not occurs yet.
This occurs on ST8 MP3 with latest graphic card drivers on severel Quadro cards.
Thanks for any information.
Ota
Re: Missing PMI text
OK, more news coming.
It appears that it has to do something with older nVidia graphics card (FX series). Customer with Quadro series are ok.
If someone wants to join, here is the IR7586192.
And for review, how the issue looks like:
(view in My Videos)
Is there a work around? We had it happen yesterday on another station
only WAs I know right now is to:
1. get back to ST7
2. get different graphics card.
3. Pray :-)
Ota
If I recall, the last Quadro FX model was new 5 years ago.  Probably time for a new card...
Production: SE 2019 MP4, Testing: SE 2020
http://Grundey.blogspot.com
Hello Ken,
you are right, but explaining this to customers is a bit difficult.
FX cards are still supported according to GTAC HW certification table for ST8.
Ota
PLM World Member Pioneer PLM World Member Pioneer
This is happening to me too.
SE 7M8, on AMD Firepro 7000.
Has anyone found a solution? Tried restarts and computer reboots. PMI text still missing. Worked yesterday, not sure what has changed.
Sort of dead in the water with no dimensions.
Hi @debris,
Have you tried installing MP10, to see if that helps....? What version of Windows are you running??
Just installed MP10 with no resulting joy. Same issue of no PMI text on both old and new parts.
Windows 7 professional service pack 1.
Hi @debris, are you running the following driver version? 14.502.1019
That is the latest driver specified on the Siemens Graphic Card certification table for support of Solid Edge.  May be different depending on what PC brand/model you have with an OEM card.
