Modal analysis of sheet metal part only shows 0.000 MHz
I'm trying to do a quick modal analysis on a sheet metal part and the result is alway 0 MHz.  I modeled a tube in the part environment with the same result.  I have also modeled a simple rod and only get 0.00 MHz.  Is there something wrong with Simulation Express or have I done something wrong for 3 different parts?
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Re: Modal analysis of sheet metal part only shows 0.000 MHz
Here are some screen shots.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Are you using ST6 or earlier? If so edit your file properties, units, advanced units and change frequency to hertz. The default is Mhz and with a resolution of 3 decimal places this will in most practical cases give a result of 0.
Cheers
Mark
Mark,
I'm running ST7.  That did the trick.  Thanks!
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
