Model View dimensions in assembly
I set up some Model Views in an assembly, and associated PMI dimensions with each.  But now when I "Apply View" on a particular model view, it does indeed turn the checks on for the associated dimension, BUT: it turns off "Dimensions" itself so no dimensions are visible.
Is there a way to change this?
